Unity distribution list issue
Oct 18th, 2007
I'm working w/ a customer on setting up distribution lists. They work, but we've found out that sometimes (more often than not) you can't send a message to a distribution list that you're a member of. We get an error at the end of the prompts when sending that says "The system is temporarily unable to complete your call, try back later".
Any ideas?
/Jake
sopayne Wed, 10/31/2007 - 16:56
  • Cisco Employee,
I've found that when creating PDLs you have to wait for AD to sync before you can send a message to the PDL, regardless of whether or not the subscriber you are sending the message as is a member.
If my suggestion is not helpful and you haven't found a resolution to your issue, I'd suggest opening a TAC case to get help on this one.
I hope this helps.
