PPP Negotiation problem
Oct 18th, 2007
I have a router (RouterB) that is not receiving LCP CONFACK messages from the sending router (RouterA). RouterB is sending a CONFREQ, RouterA is receiving it and sending a CONFACK to RouterB, but B never gets it. It is not getting any inbound messages for that matter. I had the provider test the T1 and it runs clean. Serial ports on both sides are up.
Not sure where to look next. Any suggestions?
RouterA - 1760 - 12.2(4)
CLE_1760_PPP#sh int s0/0
Serial0/0 is up, line protocol is down
Hardware is PQUICC with Fractional T1 CSU/DSU
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
reliability 253/255, txload 1/255, rxload 1/255
Encapsulation PPP, LCP Listen, multilink Closed
Closed: CDPCP, loopback not set
Last input 00:00:29, output 00:00:29, output hang never
Last clearing of "show interface" counters 06:26:26
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/1/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 1158 kilobits/sec
4609 packets input, 156706 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
690 input errors, 0 CRC, 659 frame, 0 overrun, 0 ignored, 31 abort
9237 packets output, 309430 bytes, 0 underruns
0 output errors, 0 collisions, 1235 interface resets
3 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
RouterB - 1751 - 12.1(3)
CLE_1751_PPP2#sh int s1/0
Serial1/0 is up, line protocol is down
Hardware is PowerQUICC Serial
Description: VzB PPP Ckt 1 - 1X-JSQ7-K97Y-0001
reliability 128/255, txload 1/255, rxload 1/255
Encapsulation PPP, loopback not set
Keepalive set (10 sec)
Closed: CDPCP
Last input 01:29:05, output 00:00:30, output hang never
Last clearing of "show interface" counters 06:24:10
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
3506 packets input, 56668 bytes, 0 no buffer
Received 0 broadcasts, 1 runts, 0 giants, 0 throttles
1163 input errors, 1020 CRC, 128 frame, 0 overrun, 0 ignored, 15 abort
4047 packets output, 75040 bytes, 0 underruns
0 output errors, 0 collisions, 149 interface resets
1 carrier transitions
TIA
jw
Paolo Bevilacqua Thu, 10/18/2007 - 15:08
the circuit is not running clean:
and worse
you can try encap hdlc but doesn't seem you have much better chances. you need the circuit anyway to be fixed.
colin.mccrory Thu, 10/18/2007 - 15:10
First thing I notice from your show interface commands are a lot of input errors on both routers. Have you configured the clocking correctly on these interfaces?
