Record Prompt/Delete Prompt
Oct 18th, 2007
I have wrote several in-depth Recording prompts that upload .wav's to the repository but I have never been able to "Delete Recordings" from the repository.
I would like to have a message in front of our helpdesk where the users can record a "message of the day" and delete it whenever they want. I currently have a script that works fine but the only way to delete the recording is to record a blank message and save it over the previous.
thanks in advance.
bwilmoth Wed, 10/24/2007 - 13:42
The Repository Database is meant to hold prompts, grammars,and documents used by scripts, do not use upload functionalities to
store all types of prompts, grammars, and documents. There is no provision for delete operations from scripts. Also, the system do not behave properly if these steps are over-utilized
