Cisco ACS 4.1 replication and RSA SecurID integration
kevin.jones1
I have Cisco ACS 4.1 build 23 patch 5 installed on
Windows 2003 Enterprise Edtition Server with
Service Pack 2. This Win2k3, called Win2k3-AD1,
is also an AD controller. On this AD controller
I also installed RSA SecurID Server and I integrate
SecurID with Cisco ACS. I also integrated Cisco
ACS with Microsoft LDAP on the same box.
Now I would like to install Cisco ACS 4.1 build 23
patch 5 on another W2k3 enterprise edition server,
called win2k3-AD2, AD controller and then I want
to replicate ACS between win2k3-AD1 and win2k3-AD2.
Will that work and what about the SecurID part?
Can I use both boxes for load-sharing? Like
half of my devices will go to win2k3-AD1 for
authentication and half of devices will go to
win2k3-AD2 for authentication. How will these
ACS servers handle SecurID integration?
Having a single ACS is easy with SecurID
integration, but adding another ACS makes thing
more complicated.
Comments?
Jagdeep Gambhir
Level 10
Level 10
You need to set external data setting on the second acs manually as replication does not cover it. Other way around is to take backup from primary and restore it to secondary.
Once done only things you need to be careful about IP address change in secondary.
Yes can set up load balancing , lets says you have two sites 1 and 2 . Each site have individual acs
Site 1 Site 2
ACS1 ACS 2
Now for site 1 aaa clients you need to define acs1 as primary and acs 2 as secondary ...where in on Site 2 aaa clients you need to define acs2 as primary and acs1 as secondary.
Hope that helps
~Regards,
~JG
Please rate helpful posts
I know that type of load-balancing. What
I am referring to is to put 2 ACS behind a
load balancer like a F5 BigIP so it will
balance that way. I wonder if it will work
that that way. I want all devices in my network
to have unify configuration.
you said: "You need to set external data setting on the second acs manually as replication does not cover it. Other way around is to take backup from primary and restore it to secondary."
Are you telling me that the secondary ACS
will work with RSA too? If so, how?
Did you get it working in either a lab
or production environment?
