LMS 2.6 Bundled RME couldn't get IOS from device and network
Oct 18th, 2007
My Ciscoworks server install on Solaris 9, and tftp already run, but I cannot using RME to maintain the IOS image. I tried to copy the image by command but the following error appears.
R10k8-HBT-BRAS05#copy disk0:c10k3-eboot-mz.122-31.SB5.bin tftp:
Address or name of remote host []? 192.168.2.5
Destination filename [c10k3-eboot-mz.122-31.SB5.bin]?
TFTP: error code 1 received - 18025
%Error opening tftp://192.168.2.5/c10k3-eboot-mz.122-31.SB5.bin (No such file or directory)
bash-2.05# ./mping -s tftp nms
sent: 5 recvd: 5 min: 2 max: 3 avg: 2 timeout: 2 size: 25 protocol: tftp port: 69
bash-2.05#
Brian
yjdabear Fri, 10/19/2007 - 07:35
  • Gold, 750 points or more
Did you create an empty "c10k3-eboot-mz.122-31.SB5.bin" file on the tftp server (in /tftpboot typically) before you started the CLI tftp? That's how tftp works.
So going by that thought, does your CiscoWorks have write access to your tftp root directory, whatever you designated it to be in CiscoWorks?
nhubinh Sun, 10/21/2007 - 20:39
Thank you for your support, now I can copy the image using command line on the router. However, in Ciscoworks I cannot copy the image to the Software Repository from device or network.
Brian
