ACS to PIX download IP address
Oct 18th, 2007
Hi, I'm new in this forum. I'm trying to configure a VPN tunnel using PIX, ACS and certificates. I can make the VPN tunnel but I can't push an IP address from the ACS ip pools to the VPN Client. Someone can help my?. I need to use Cisco RADIUS av-pair?. Thanks for your help.
Jagdeep Gambhir Fri, 10/19/2007 - 09:01
I would suggest you to let pix assign the IP address instead of ACS.
The reason for this is we are getting many cases where sometime acs do not assign IP address.
ASA's and VPN conc. are not designed to take IP address from acs.
It will work but there is no consistency.
~JG
Please rate if helps
