Static Route with Tag number
Answered Question
Oct 18th, 2007
  • Bronze, 100 points or more
Does this command
ip route 10.64.0.0 255.240.0.0 192.168.50.2 20 tag 102
overwrites this command
ip route 10.64.0.0 255.240.0.0 192.168.50.2 10 tag 101
? or vise versa?
Thanks in advance
Abd Alqader
Correct Answer by ilya.varlashkin about 9 years 9 months ago
Routes must have different next-hop in order to be different, otherwise they're considered as the same route so second command overwrites first one.
Overall Rating: 4 (2 ratings)
Danilo Dy Thu, 10/18/2007 - 22:16
  • Blue, 1500 points or more
The tag is use to reference a route in a route map for making policy decision.
You have two floating static route diferrentiated by their administrative distance of 10 and 20. I don't think the routes overwrite each other by the tag.
Dandy
a.hajhamad Thu, 10/18/2007 - 23:22
Hi Dandy,
Yes, this is right. But, why when i apply these two static routes at Cisco 6509 switch, the last one applied is the one appeared at the show running?
Abd Alqader
Correct Answer
ilya.varlashkin Thu, 10/18/2007 - 23:27
  • Silver, 250 points or more
Danilo Dy Fri, 10/19/2007 - 00:18
I didn't noticed the next hop which is the same. The second one will overwrite the first one with or without tag.
Dandy
a.hajhamad Fri, 10/19/2007 - 02:21
yes, you are right.
marhoel_it Mon, 10/29/2007 - 23:10
Hi i have 2 ISP connected to cisco 2811 router, i want to configure a failover on wan side what can i do. i made some configuration on it using route-map ang policy list but it didnt work
my config is
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 2 permit 192.168.2.0 0.0.0.255
ip policy-list group1-s1/0 permit
match ip add 1
match int s1/0
ip policy-list group1-s1/1 permit
match ip add 1
match int s1/1
ip policy-list group2-s1/0 permit
match ip add 2
match int s1/0
ip policy-list group2-s1/1 permit
match ip add 2
match int s1/1
route-map group 1 permit 1
match policy-list group1-s1/0
match policy-list group1-s1/1
route-map group 2 permit
int s1/0
ip nat outside
ip policy route-map group1
int s1/1
ip nat outside
ip policy route-map group2
ip nat inside source list route-map group1 int s1/0
ip nat inside source list route-map group2 int s1/1
