2610 XM problem
Oct 18th, 2007
Hi all,
iam having 2610XM router on which i need to go to ROMMON mode but it is not taking ctrl+pausebreak is there any other solution even its not going ahead wait on ISAKMP OFF wat is the cause of this error.
htarra Wed, 10/24/2007 - 14:04
  • Bronze, 100 points or more
Generally he router does not recognize the Ethernet ports, so recovery needs to be done from ROM Monitor (ROMmon) mode. Power cycle the router and press Ctrl+Break as it boots. The router goes to the ROMmon prompt. Router comes up in Rom mode after reload by power.
For instructions on loading the correct Cisco IOS Software version, http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008015bfac.shtml
