Load Balancing - How to check if balancing is working correctly
Oct 19th, 2007
Hi All,
I am trying to check and ensure load balancing is working fine on 2 of my links, one from HO and one from Disaster Recovery Center to one site?
gaurav_thapar79 Fri, 10/19/2007 - 05:27
please share the exact scenario and what type load-sharing have you configured?
Its difficult to understand the scenario and correlate it with your query and requirement.
The problem statement itself does not share anything and does not lead towards problem and the subsequent resolution.
Edison Ortiz Fri, 10/19/2007 - 05:30
show interface on both links should produce the same amount of input/output packets if you are using per-packet load-balancing.
If you are using destination load-balancing (which is the default method), the output from both interfaces won't be the same but you should see traffic on both links.
