How to use 2 AAA server for different login purpose
Answered Question
Oct 19th, 2007
Hello, could you help me?
This is a part of my configuration; I would like to add another TACACS server, witch should take care of the telnet at vty 0 4.
The Tacacs server 10.20.30.40 takes care of the virtual access, and I have another Tacacs server who takes care of login on our network equipment.
! Cisco 7204 with system flash c7200-io3s56i-mz.121-4.bin
aaa new-model
aaa authentication login default group tacacs+
aaa authentication login no_tacacs enable
aaa authentication ppp default group tacacs+
aaa authorization exec default group tacacs+
aaa authorization network default group tacacs+
aaa accounting exec default start-stop group tacacs+
aaa accounting network default start-stop group tacacs+
aaa accounting connection default start-stop group tacacs+
virtual-profile virtual-template 1
virtual-profile aaa
interface Serial2/0:15
description ISDN30
no ip address
encapsulation ppp
no ip route-cache
no keepalive
dialer pool-member 10
isdn switch-type primary-net5
isdn tei-negotiation first-call
isdn caller xxxxxxx
no fair-queue
compress stac
no cdp enable
ppp authentication chap
ppp multilink
interface Virtual-Template1
ip unnumbered FastEthernet1/0
ip nat outside
tacacs-server host 10.20.30.40 key ********
line con 0
exec-timeout 20 0
password ************
login authentication no_tacacs
transport input none
flowcontrol hardware
line aux 0
line vty 0 4
access-class 1 in
exec-timeout 60 0
password *************
transport input telnet
transport output telnet
If I just add
aaa authentication login vtymethod group tacacs+ enable
tacacs-server host 10.50.60.70 key ********
line vty 0 4
login authentication vtymethod
My telnet request ask 10.20.30.40 and I have a deny! Could you help to make a secure solution?
Correct Answer by Richard Burts about 9 years 6 months ago
Jens
I believe that your solution would be to configure a different tacacs server group with the new server in the new group and to use the new group to authenticate for your vty. The config might look something like this:
aaa group server tacacs+ vty_TAC
server 10.50.60.70
aaa authentication login vtymethod group vty_TAC enable
I have configured this type of thing and it worked well. When I configured it I explicitly configured (and named) two different TACACS server groups and referenced specific server groups for each authentication method. I am not clear whether it works to keep the default group tacacs+ and use it for your normal authentication or whether you may need to configure a non-default group for it.
Give it a try and let us know what happens.
Rick
Overall Rating: 5 (1 ratings)
Correct Answer
Richard Burts Fri, 10/19/2007 - 06:47
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jens
server 10.50.60.70
Rick
