enabling ssh ion 2970 swicth
Oct 19th, 2007
How to enable ssh on 2950 with cisco IOS software C2970 ( C2950-LANBASE-M) Version - 12.2(25) SEB4.
I tried with crypro key generate rsa command. but it seems command is not supported. On this version of IOS.
Any link on Cisco.com
Thanks in advance
Subodh
Overall Rating: 4 (2 ratings)
glen.grant Fri, 10/19/2007 - 08:42
  • Purple, 4500 points or more
Use "crypto key generate rsa modulus . You insert the length of the modulus key . Also you have to make sure you have the crypto version of code and by just looking at it it does not look like you do. Upgrade to crypto code to use SSH.
