Route Pattern (translations)
Answered Question
Oct 19th, 2007
Hi !
Some of my IPPhones, when making an external call, they use the ''Calling Party Transform Mask'' in the route pattern configuration.
For example, the ipphone extension is 7050, but when I dial to an external number I goes like 4265.
So the calls goes to a gateway.. and the translation works fine...
The problem happens when I call to another ip phone in another partition.. (the call doesn't need to go to the gateway).. so the ip phones can see the real extension (7050) instead of mask (4265)
Is it possible to mask that ? How ?
Thanks.
Andrei.
Correct Answer by jbarcena about 9 years 7 months ago
Make sure that the CSS that is assigned to the calling party can NOT reach the called party partiton, otherwise you will bypass the Translation Pattern and that is why you are still getting the original caller ID. The CSS of the calling party must reach only the partiton of the Translation Pattern and then the CSS of the Translation Pattern must reach the partition of the called party phone.
//Jorge
Overall Rating: 5 (2 ratings)
pklos Fri, 10/19/2007 - 05:07
  • Silver, 250 points or more
You can pass call to other partition via Translation Pattern and use "Use Calling Party's External Phone Number Mask". Don't change called party number, just provide proper CSS.
regards,
pk
andrei.goncalves Fri, 10/19/2007 - 07:26
humm.. I tryied some things... I it did not work...
I don't know what I'm doing wrong.. I tryied this:
- translation pattern: 4XXX
- partition where calling ip phones are: PT-MASK
- CSS from the calling ip phones: CSS-MASK
- CLICK "Use Calling Party's External Phone Number Mask"
- Field "Calling Party Transform Mask" = 4265
Andrei.
Correct Answer
jbarcena Fri, 10/19/2007 - 13:43
  • Red, 2250 points or more
//Jorge
andrei.goncalves Mon, 10/22/2007 - 02:59
Now I understood !! It's working..
Translation Patterns works like Route Patterns..
Thanks a lot.
Andrei.
