Unity 5.0 backup
Oct 19th, 2007
Hi there,
I need to backup my Unity 5.0 and was wondering if it will support SSH/SFTP method.
All other appliance model of IPT application support SSH/SFTP, except UCCX 5.0 and Unity which are still under windows platform. Is there a way to get these 2 backed up to SSH/SFTP server?
thisisshanky Fri, 10/19/2007 - 09:29
The backup tool can be accessed from Tools Depot -> DIRT backup/restore. DIRT stands for Disaster Recovery tool. It cannot use SSHP/SFTP but you can back up the data to a local share or to a network share. When using NEtwork share, i would suggest you check the two hop method of backing up sql data first locally in a temp folder and then it will automatically move the data to the network share. I usually map a network drive on the server and then specify the :\folder\ as the path. There is a way to schedule a dirt back up on the task scheduler as well.
Sankar
PS: please remember to rate posts!
