VRF
Oct 19th, 2007
Hi, We 'got a network with a collapsed core
( SVI with ACL ) with 30 vlans crossed all over .
We want to migrate with hierarchical model .I 'm asking about solutions
THe need is to activate HSRP and for routing OSPF.
I heard about VRF lite
but how could it help me in this design?
Thanks for help.
royalblues Mon, 10/22/2007 - 09:16
  • Green, 3000 points or more
VRF lite would certainly help for isolating the VLANS and can take care of the ACL's in the SVI.
Create VLANs and associate each vlan with a paricular VRF forwarding instance.
If you have 2 core/dist switches, connect the access switches to each core and enable uplinkfast. HSRP can be configured for VLANS for redundnacy.
We need more information abut your WAN topology to discuss OSPF routing
Narayan
fd_case17 Sun, 10/28/2007 - 06:37
hi,
It's for the LAN .
We want to make a new topology
Like the hierarchical model.
1 core with 2 routers
3 distributions with 3750 ( 3*2 3750)
acces layer 2950
So ok for uplinkfast on the 2950,
we want hsrp in the distribution ( for 4 vlans
/disribution)
The link between the distribution and the core might be routed ports, so we need a routing protocol .
I'masking if hsrp and the routing protocol might be correlate and how
