Unified Communications 6.x
Oct 19th, 2007
how do I upgrade my callmanager to the latest version, I already downloade the part 1 and 2 of the upgrade and burned it in a DVD, however when i go to OS administrator and try to upgrade the first node, I need to specify a directory and I don't know how to go from there.
any help is appreciated
Overall Rating: 3 (2 ratings)
thisisshanky Fri, 10/19/2007 - 08:13
  • Purple, 4500 points or more
Are you attempting an upgrade from windows version CM (3.x/4.x) to CM 6.0
cris_jimenez Fri, 10/19/2007 - 08:16
no I'm running CM 6.0.1.2000-3 and I want to upgrade to 6.0.1.2000-4
thisisshanky Fri, 10/19/2007 - 09:27
You can download the bin file from CCO and then go to OS administration, software upgrades menu and upload it via SFTP or via a DVD/CD media.
kim_beadle Fri, 08/29/2008 - 06:28
How do you go about the upgrade with 2 x 1.1gb files over SFTP.
Are you able to upload them both and then they find themselves in the inactive partition ready for reboot into that partition?
cris_jimenez Fri, 08/29/2008 - 07:04
Kim,
once you downloaded the 2 parts you need to open a dos prompt and run the following commmand if you are on windows, go to the directory where you have the 2 1.1 gig files and execute the following command
COPY /B UCSInstall_UCOS_6.1.2.1000-13.sgn.iso_part1of2+UCSInstall_UCOS_6.1.2.1000-13.sgn.iso_part2of2 UCSInstall_UCOS_6.1.2.1000-13.sgn.iso
just copy paste it and this command will make the 2 files only 1 iso that you will be able to upload to the callmanager through SFTP
hope this helps
kim_beadle Sun, 08/31/2008 - 05:22
Thanks Cris, I eventually found this info in the readme PDF for the download.
