WAN simulation
Oct 19th, 2007
I am building out a DR infrastructure for a remote site but do to time constraints and complexity the environment needs to be built within our LAN. We currently utilize 6513 switches at the core and are hoping to connect in a 2600 series router using a seperate IP range for the DR systems. I'm just looking ofr the best way to accomplish this
spremkumar Mon, 10/22/2007 - 23:58
Do throw more clarity on what kinda info you require/expect out here.
AFAIK the basic details like replication method need to be decided (async/sync).
Based on the same the bandwidth requirement between the data centers can be worked out.
Once you are done with the bandwidth requirements you can decide on the kinda hardware equipment required/capable of handling the same.
regds
