ISDN<=>VOIP routing help
Oct 19th, 2007
hi. ive posted a bit earlier as well, same problem. but now ive advanced a bit.
through all the doc's that ive seen,
all of them have the voice-port interface. i cant get to that command. my ios is 2800NM-IPVOICEK9-M), Version 12.4(15)T1, perhaps im doing something in the wrong order?
what steps do i need to follow next,
in order to be able route my incoming calls to the appropriate phone?
ahh...i didnt mention in my original post how my network is layed out..
i have my cisco router 2811...and anything that comes into it is forwared by nat out the fa0/0 interface where there is a asa5505.
my vlans reside from there on out. my router doesnt have any vlan configurations. the asa5505 take what ever comes into its outside port and forwards it to the appropriate vlan. after the asa 5505 i have a cisco catalyst express500...
so basically, what are the steps (in general or not) that i need to follow to get the voice routed inside.
ive added my bri interfaces so you can have a proper look:
interface BRI0/1/0
no ip address
no logging event link-status
isdn switch-type basic-net3
isdn tei-negotiation first-call
isdn point-to-point-setup
isdn incoming-voice voice
isdn sending-complete
trunk-group my-trunk
interface BRI0/1/1
no ip address
trunk-group my-group
thanks
paolo bevilacqua Fri, 10/19/2007 - 09:01
  • Hall of Fame,
    Founding Member
Do you have DID service on these lines ?
