EIGRP over GRE tunnel
Oct 19th, 2007
Have A customer of would like to implement EIGRP over GRE, would routers drop the Multicast routing updates.
The Multicast has a TTL of 1 but the GRE tunnel shows no hop.
thank you
Overall Rating: 4 (1 ratings)
Edison Ortiz Fri, 10/19/2007 - 09:49
  • Hall of Fame,
    Founding Member
When creating the GRE tunnel, make sure they are part of the same IP subnet.
Example,
RouterA
interface tunnel1
ip address 10.0.0.1 255.255.255.252
router eigrp 1
network 10.0.0.1 0.0.0.0
RouterB
interface tunnel2
ip address 10.0.0.2 255.255.255.252
router eigrp 1
network 10.0.0.2 0.0.0.0
it should work w/o problems (need to verify reachability beforehand).
Richard Burts Fri, 10/19/2007 - 09:59
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
I have run EIGRP over GRE tunnels many times. It works. The TTL is not an issue. The EIGRP multicast packet with TTL of 1 is encapsulated in an IP unicast header for transmission to the tunnel destination. It is the TTL of the GRE header that is decremented as the packet is forwarded through intermediate networks toward the tunnel destination. At the tunnel destination when the EIGRP packet is evaluated its TTL is valid.
Rick
Edison Ortiz Fri, 10/19/2007 - 10:27
  • Hall of Fame,
    Founding Member
TTL on a tunnel is not an issue as unicast/multicast traffic is treated as being on the same segment.
