Any body know how to fix this 2900XLswitch problem
Switch2900Xl#
%IP-4-CLASS: Bad IP address and mask 0.0.0.0/32 in class_resolve()
%LINK-5-BOOTP: VLAN1 address 0.0.0.0, resolved by 192.168.1.250
Edison Ortiz Fri, 10/19/2007 - 12:34
  • Hall of Fame,
    Founding Member
It sounds like you haven't assigned an IP to Vlan1 (management Vlan on 2900XL) and the switch is trying to obtain any IP via DHCP.
Manually enter an IP under interface Vlan1 or shutdown the interface if you aren't planning to use it for management.
Edison Ortiz Fri, 10/19/2007 - 13:43
  • Hall of Fame,
    Founding Member
please post the switch config.
version 11.2
no service pad
no service udp-small-serversctive help system 0.0.0.0/32
no service tcp-small-servers
hostname Switch2900XL Set system'
!n
!w
no ip routing0.0.0.0, reso
!e
interface VLAN150sk
no ip route-cache Sele
interface FastEthernet0/1
% Invalid inp
interface FastEthernet0/2
ip
interface FastEthernet0/3k
interface FastEthernet0/7
interface FastEthernet0/8ac-address-table
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
line con 0
stopbits 1
line vty 0 4
login
end
Edison Ortiz Fri, 10/19/2007 - 14:44
  • Hall of Fame,
    Founding Member
enter the following commands:
configuration terminal
interface Vlan1
shutdown
end
wr t
Are you still seeing those errors after this ?
Edison Ortiz Fri, 10/19/2007 - 17:05
  • Hall of Fame,
    Founding Member
give it a valid ip address with the following commands,
interface vlan1
end
wr
___________
Please replace the ip address above with an IP address that is within your network. This IP address must be reserved and no other device should use it. This way you can telnet to the switch from remote and manage it just like you are doing from the console port.
