Route without NAT between DMZs on PIX
I have 4 active interfaces on my PIX 520, Outside, Inside, DMZ1BU, and DMZ2BU. Inside, DMZ1BU and DMZ2BU can nat to outside just fine, everything on the DMZ has a static mapping to and Outside IP Address. I'm trying to route between the two DMZs and just can't get it to work. Here is the cut of the relevant part of the config.
interface ethernet0 100full
interface ethernet1 100full
interface ethernet4 auto
interface ethernet5 auto
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet4 DMZ2BU security50
nameif ethernet5 DMZ1BU security40
access-list nonat_dmz1 permit ip host 10.10.15.151 host 10.10.12.145
access-list nonat_dmz2 permit ip host 10.10.12.145 host 10.10.15.151
ip address outside x.y.z.3 255.255.255.0
ip address inside 192.168.254.1 255.255.255.0
ip address DMZ2BU 10.10.12.1 255.255.255.0
ip address DMZ1BU 10.10.15.1 255.255.255.0
ip verify reverse-path interface outside
global (outside) 1 x.y.z.5
nat (outside) 0 access-list outside_nat0_inbound outside
nat (inside) 0 access-list 101
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
nat (itf3) 1 0.0.0.0 0.0.0.0 0 0
nat (DMZ2BU) 0 access-list nonat_dmz2
nat (DMZ2BU) 1 0.0.0.0 0.0.0.0 0 0
nat (DMZ1BU) 0 access-list nonat_dmz1
nat (DMZ1BU) 1 0.0.0.0 0.0.0.0 0 0
static (DMZ1BU,outside) x.y.z.151 10.10.15.151 netmask 255.255.255.255 0 0
static (DMZ2BU,outside) x.y.z.170 10.10.12.145 netmask 255.255.255.255 0 0
access-group acl_outside in interface outside
access-group acl_dmz2 in interface DMZ2BU
access-group acl_dmz1 in interface DMZ1BU
route outside 0.0.0.0 0.0.0.0 x.y.z.1 1
I really think systems on DMZ1 and DMZ2 should be able to ping each other without NATing with this config, but it doesn't work. Am I missing something really obvious? I'm attaching the full config in case there in information not here that is needed.
Thank you for your assistance. I've been searching online and everything I've found leads me to beleive my config is correct.
acomiskey Fri, 10/19/2007 - 11:16
  • Green, 3000 points or more
Try this instead of the nat 0 commands...
no nat (DMZ1BU) 0 access-list nonat_dmz1
no nat (DMZ2BU) 0 access-list nonat_dmz2
static (DMZ2BU,DMZ1BU) 10.10.15.0 10.10.15.0 netmask 255.255.255.0
I had tried that also, although I did do it the other way around with static (DMZ1BU,DMZ2BU) 10.10.12.0 10.10.12.0 netmask 255.255.255.0, and it did not work either. I just tried it with your exacty commands and 10.10.12.145 could still not ping 10.10.15.151.
Do I need to clear xlate after making this change? I've looked at the xlate table and don't see any entries for this. I hate doing a full xlate table clear during the day.
acomiskey Fri, 10/19/2007 - 11:27
You have not allowed icmp replies back into the DMZ1 interface....
access-list acl_dmz1 permit icmp any any echo-reply
or
acomiskey Fri, 10/19/2007 - 11:40
No problem, did you also add...?
access-list acl_dmz2 permit icmp any any
acomiskey Fri, 10/19/2007 - 11:54
Weird, this shouln't be this hard. Want to post the new updated config?
acomiskey Fri, 10/19/2007 - 12:19
Sorry, that's my bad, I was reading too fast...
no static (DMZ2BU,DMZ1BU) 10.10.15.0 10.10.15.0 netmask 255.255.255.0 0 0
static (DMZ2BU,DMZ1BU) 10.10.12.0 10.10.12.0 netmask 255.255.255.0 0 0
clear xlate
acomiskey Fri, 10/19/2007 - 12:40
That's crazy. Time to start logging on the pix when you try to ping. You are trying to ping from 10.10.12.x to 10.10.15.x right. Try to get some logging going to see what the pix is saying as you ping.
Hmm, ok, doing a debug icmp trace if I ping from 10.10.12.145 to 198.6.1.4 on the outside I see all the records and it looks fine, which is good because that works. But if from 10.10.12.145 I ping 10.10.15.151, there is no record in the debug, none at all.
The only thing that I can think of is that all of these servers have static mapping to outside. Does that superseed the static (dmz1bu,dmz2bu) ... and the nat 0 lines because it comes first?
slayerhawk Wed, 05/14/2008 - 10:18
Did you ever figure this out? I have a similar issue and am confused.
