extra server on cisco ACS engine
netopia
I'm a bit curious about the way the cisco ACS engine (the cisco-built hardware) sets up servers initially. Most of the documentation I have is for windows, so I was a bit confused when, after the initial configuration there were two "AAA Servers" shown in the configuration, one called "Self" with the IP address I defined, and the other with the name I defined and a different address.
Has anyone else encountered this? Will it cause problems? and is there a way to get rid of it?
Jagdeep Gambhir
Level 10
Level 10
That is a known issue with acs appliance, but nothing to worry about. Make sure you have this setting in acs,
acs--->network configuration--->Proxy dis table---> Bring Deleverance1 in the fwd to box and your server name in the left box.
Incase you dont see proxy dis table , then you need to enable it
Interface configuration---> Advance option ---> Put a check in distribution table.
~JG
Please do rate helpful posts
