PIX with 2 HTTP Routes
Answered Question
Oct 19th, 2007
My PIX currently has this statement:
static (inside,outside) tcp 74.74.74.74 www 192.168.10.5 www netmask 255.255.255.255 0 0
now I also want my box at 192.168.10.6 to be hittable with the real IP 74.74.74.75
yet I keep getting an "overlaps with" error out of the PIX when I issue the command to enable it. What am I missing?
Correct Answer by acomiskey about 9 years 6 months ago
Ok so if you wanted
static (inside,outside) 74.74.74.75 192.168.10.6 netmask 255.255.255.255 0 0
it appears you already have it!
My guess is it gave you a warning the first time you entered it, then you tried to enter it again and is giving you an error because it already exists.
Overall Rating: 4.5 (2 ratings)
acomiskey Fri, 10/19/2007 - 11:52
  • Green, 3000 points or more
So you added...?
If it says "INFO:..." it is just an information message, not an error.
townofnewmarket Fri, 10/19/2007 - 12:04
I added:
and I get this:
ERROR: static overlaps with 74.74.74.75 to 192.168.10.6
acomiskey Fri, 10/19/2007 - 12:04
What other statics do you have in place?
townofnewmarket Fri, 10/19/2007 - 12:12
static (inside,outside) tcp interface 3389 192.168.6.9 3389 netmask 255.255.255.255 0 0
static (inside,outside) tcp interface telnet 192.168.1.201 telnet netmask 255.255.255.255 0 0
static (inside,outside) tcp 74.74.74.74 https 192.168.10.5 https netmask 255.255.255.255 0 0
static (inside,outside) 74.74.74.74 192.168.10.5 netmask 255.255.255.255 0 0
acomiskey Fri, 10/19/2007 - 12:15
You can't have both of these at the same time...
static (inside,outside) 74.94.136.137 192.168.10.6 netmask 255.255.255.255 0 0
as they both have 192.168.10.6.
townofnewmarket Fri, 10/19/2007 - 12:18
typo on my part!
that first line was from an older config and does not apply. I corrected it in my previous post.
Correct Answer
acomiskey Fri, 10/19/2007 - 12:22
Ok so if you wanted
