10-19-2007 12:00 PM - edited 03-15-2019 12:04 AM
Where do I add a user to the "Customer Response Solutions Administration" administrator section?
Solved! Go to Solution.
10-19-2007 12:12 PM
You would go under IPCC, User management menu and add a user as administrator.
10-19-2007 12:12 PM
10-19-2007 12:31 PM
Thank you!
10-19-2007 12:38 PM
Used to be that in the older version Customer Response Applications Administration which is now Customer Response Solutions Administration you could select "ICD" under the Subsystems. Where is that option now? Any idea?
thanks again!
