Change the Caller ID information of an incoming PSTN Call
Oct 19th, 2007
I am geting ready to purchase a Call Manager Solution. I have 4 operating companies that work out of the same office, infact they are the same people staffing each company. I want to get a T1 wor the voice that comes from the pstn I am assuming if I have a DID number from the PSTN for each company CM will see both the ID information for the outside caller and the number they called in on. what I would like to do is tag the caller ID information With the name of the company inside employees should answer the phone with, "thank you for company 1". I know I can put multiple DNs on a phone and route the DID to the DN so it works like the Key system we have now but having something on the screen like CO1 - Name of the Customer who called - Customer's Phone number would just be cool. Is there a way to accomplish this with a transform?
paolo bevilacqua Fri, 10/19/2007 - 13:09
  • Hall of Fame,
    Founding Member
Hi, the multiple buttons is the correct setup. I also believe you can configure CM so directory is looked up if the switch doesn't deliver a calling name. At least CME is surely possible.
