SSL VPN behind PIX 515
Oct 19th, 2007
I hope somebody can help with this
I have a SonicWall SSL-VPN 2000 behind a PIX 515 which I cannot access from outside.
The configuration is like this:
name x.x.x.x SSLVPN_Ext
name y.y.y.y SSLVPN_Int
static (inside,outside) SSLVPN_ext SSLVPN_Int netmask 255.255.255.255 0 0
access-list SonicWallVPN line 1 permit tcp any host SSLVPN_Ext eq https (hitcnt=0)
Thanks in advance
stephan
tstanik Thu, 10/25/2007 - 10:43
Configure following commands in PIX
access-list SonicWallVPN line 1 permit any host SSLVPN_Ext eq https
jaravinthan Thu, 10/25/2007 - 23:58
though the answer seems to be dumb
is the ACL applied in outside interface in inward direction?
and configuring the NAT as
static (inside,outside) SSLVPN_ext 443 SSLVPN_Int 443 netmask 255.255.255.255 0 0
Matt Lang Thu, 05/01/2008 - 05:55
Stephan,
I am experiencing the same thing. Did you ever get this to work?
Matt
jaravinthan Sun, 05/04/2008 - 19:07
another silly check...
please try allowing HTTP as well towards the public IP and the below command
http 255.255.255.255
