PPPoE Server with DHCP
Oct 19th, 2007
I am helping my customer to test the PPPoE solution. The requirement is that she like to have a PPPoE server (7200), enable the DHCP pool on the router. The PPPoE client (1811) should receive the IP address through the DHCP and with subnet mask (/24) so that routing protocol can enable between the PPPoE server and client.
We test with some initial configuration but not success to obtain DHCP address from the pool.
On PPPoE server router,
ip dhcp pool DHCP-PPP
interface FastEthernet0/1
no ip address
duplex auto
speed auto
pppoe enable group global
interface Virtual-Template1
ip address
peer default ip address dhcp-pool DHCP-PPP
ppp authentication pap
However, the router pppoe client cannot obtain the dhcp address.
If I use the peer local pool, not dhcp pool, I can only assign /32 address to the client. i.e.
ip address
peer default ip address local TEST authentication pap
ip local pool TEST
Is there any method to achieve the requirement?
Overall Rating: 5 (1 ratings)
Dominic Stalder Thu, 01/26/2012 - 23:03
Hi Chow
Just to let you know, I solved it with the following RADIUS attribute to enable the client to get a address out of a ip local pool TEST:
Attribute: cisco-av-pair
Value: ip:addr-pool=TEST
Best regards
