cisco 2610xm router for ccnp
Oct 20th, 2007
I am about to start my studies for ccnp. I need to build a home lab (I do have some equipment but need some more). So I am wondering if a cisco 2610XM router is good buy for $265 on ebay. here is the config provided by the seller:
Router#sh ver
Cisco IOS Software, C2600 Software (C2600-ADVENTERPRISEK9-M), Version 12.4(3b),)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Thu 08-Dec-05 17:37 by alnguyen
ROM: System Bootstrap, Version 12.2(7r) [cmong 7r], RELEASE SOFTWARE (fc1)
Router uptime is 3 minutes
System image file is "flash:c2600-adventerprisek9-mz.124-3b.bin"
This product contains cryptographic features and is subject to A summary of U.S. laws governing Cisco cryptographic products may be found at:
Cisco 2610XM (MPC860P) processor (revision 0x100) with 127627K/3445K bytes of m.
Processor board ID JAE07340X6H (685427521)
M860 processor: part number 5, mask 2
1 FastEthernet interface
32K bytes of NVRAM.
49152K bytes of processor board System flash (Read/Write)
thanks for your input
sannymlao Sat, 10/20/2007 - 01:52
No. You can buy it on ebay for around $180-$200 (128MB/32MB flash). You can try to make a best offer to the seller for around $230 since it's a 48MB flash or ask the seller to include WIC-1T card and one DCE/DTE DB-60 back-to-back crossover cable.
I hope will help.
NoCertGuy Sat, 10/20/2007 - 13:02
You don't care about processor and memory too much since nothing you can do in your lab will tax the system. The most important thing is to have an IOS version (or ability to obtain one) with all the IP protocols you wan't to play with.
You might also want to look at used 800 series soho routers. I've seen some pretty tricked out 870's. If you search for the old 806s or 831s, they often came with images that supported a lot of protocols, then they got worried this was too useful to the customer and split to the 850 870 series.
sannymlao Mon, 10/22/2007 - 22:12
Hi!
Here's a 2620XM 96MB/32MB flash in ebay with a 100% positive feedback with complete accessories such as console cable, rack mount kits and AC cord from $170-$190. I think you can make a deal of $175 in it. Here's the link:
http://cgi.ebay.com/Cisco-2620XM-Router-32-96-VPN-FW-3DES-30-Day-War-07_W0QQitemZ200165710278QQihZ010QQcategoryZ67324QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Another one with an aution start from $100.
http://cgi.ebay.com/Cisco-2600-series-2620XM-router-w-1DSU-T1-WIC_W0QQitemZ330179184263QQihZ014QQcategoryZ67324QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I hope will help.
