how to verify eBGP Load-sharing
Answered Question
Oct 20th, 2007
Hi All
Two eBGP routers peer across two parallel serial links of equal bandwidth. I have configured loopback interface as an update source and eBGP-multihop on both routers.
Is here a way I could verify load-sharing is functioning accross the two parallel links?
Tia
Correct Answer by Danilo Dy about 9 years 8 months ago
You mean you have RouterA and RouterB with two parallel serial links and you configured eBGP using loopback, static route each router loopback, and configure ebgp-multihop?
From RouterA traceroute loopback IP of RouterB. It should show two IP Address in the first hop. http://www.cisco.com/warp/public/459/40.html
Also, you can setup an MRTG to monitor it permanently.
Dandy
Overall Rating: 4 (1 ratings)
Correct Answer
Danilo Dy Sat, 10/20/2007 - 06:55
  • Blue, 1500 points or more
Dandy
Richard Burts Sat, 10/20/2007 - 09:10
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Mabrouk
In addition to the suggestion from Dandy I would suggest that one way to check might be to do show interface for both serial interfaces. If the packet count (inbound and outbound) is going up on both interfaces then it is proof of load sharing.
Rick
