ACL for Policy NAT in PIX 7.2
Oct 20th, 2007
ACL counters for the access-lists applied on a Policy NAT is not incrementing in PIX 7.2. Can anyone explain me this? Also, is there something we can do to make this work?
tstanik Thu, 10/25/2007 - 11:51
In most cases when ACL counters do not increase this means that the repective ACL is not getting hit. Do you face similar problem with other ACL counters also or this is the only case. Check for the Polict NAT config and see if it is proper.
