Native VLAN mismatch discovered on switch
whiteford
I keep getting these 2 syslog errors:
4767: 004805: * Native VLAN mismatch discovered on FastEthernet0/2 (2), with switchcore5 FastEthernet0/21 (1).
And then the opposite direction
4768: 004806: * Native VLAN mismatch discovered on FastEthernet0/21 (1), with switchcore5 FastEthernet0/2 (2).
It's a Cisco Cataylst 2950 and I have updated the IOS to the lastest, everything seems to be working ok.
The 2 ports are below:
interface FastEthernet0/2
description Link - Core Switch to LAN
switchport access vlan 2
switchport mode access
speed 100
duplex full
interface FastEthernet0/21
description VLAN 1 for LAN IP
7 Replies 7
ankbhasi
Hi Andy,
This message indicates that the native vlan on trunk ports or vlans on an access ports does not match on the 2 sides.
If you check your config then on int fa0/2 the access vlan is 2 but on fa0/21 I believe you have configured it for vlan 1 although this is not the complete config which you have posted from int fa0/21 but description says it is for vlan 1. Now in this case vlans are different on both the ends and both the ports are connected to each other and CDP will report this message.
If it is intentionally designed for some purpose then you can disable CDP and you will not see this message or else you can configure interface fa0/21 as an access port and assign it to vlan2 something like this
interface fa0/21
Ankur
*Pls rate all helpfull post
Hi, that is the complete config for port fe0/21. Both ports go into the LAN switches. I think if it's not in a VLAN it goes into VLAN 1? all I need VLAN 1 on FE 0/21 is so I can manage the switch via an IP address.
Let me know if you want the full config or if there is a better way to do this. fe0/2 I need to stay where it is.
VLAN 2 I have our and firewall inside port only and this link to the LAN.
Hi Andy,
Your fa0/21 is not connected to fa0/2? If yes the config on both the sides should be same? Your fa0/2 is in dynamic desirable mode and also in vlan 1 and your fa0/21 is in access mode and in vlan2.
Now as you know any port default in in vlan 1. If these ports are connected to each other then you can configure them also a trunk port so that it can allow both the vlans?
Ankur
I'm not sure I understand. fa0/2 is in Vlan2 and fa0/21 is in Vlan1, how is fa0/2 in vlan1 too?
I would like to keep vlan2 as it is. The Vlans just both go into the LAN for our office but they are different switches.
All I want to use fa0/21 for is to telent to the switch and be able to ping it. Am I doing it the right way?
Hi Andy,
Sorry I typed wrong port numbers in my last post. Anyways what you are doing is correct as per your description. My only concern is you are getting "Native Vlan Mismatch" message and I will like to know these ports are connected to which devices?
Fa0/1 and fa0/21 are connected to each other or some other devices?
Ankur
All I can tell you as I'm not at work is that both ports connect to a huge core switch. They each go into a different vlan each. I have only got these errors since upgrading the ios, as it was 3 years old. What actually causes this native vlan error?
Is this any help? Should negotiation of trunking be on or off?
switch#show interfaces fastEthernet 0/2 trunk
Port Mode Encapsulation Status Native vlan
Fa0/2 off 802.1q not-trunking 1
Port Vlans allowed on trunk
Fa0/2 2
Port Vlans allowed and active in management domain
Fa0/2 2
Port Vlans in spanning tree forwarding state and not prune
Fa0/2 2
switch#show interfaces fastEthernet 0/21 trunk
Fa0/21 desirable 802.1q not-trunking 1
Fa0/21 1
Fa0/21 1
Fa0/21 1
switch#
and
switch#sho int fa0/2 swi
Switchport: Enabled
Administrative Mode: static access
Operational Mode: static access
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: native
Negotiation of Trunking: Off
Access Mode VLAN: 2 (fwinside)
Trunking Native Mode VLAN: 1 (default)
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk private VLANs: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
switch#sho int fa0/21 swi
Switchport: Enabled
Administrative Mode: dynamic desirable
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Voice VLAN: none
Protected: false
switch#
