ACL Logs doesn't appear
Oct 21st, 2007
I have an ACL which is working fine.
permit ip any host 204.73.44.226 (32 matches)
permit udp any any eq snmp (22 matches)
permit tcp any any eq 2967 log (7173566 matches)
deny ip any any (255731 matches)
when i do show logging i can see the permit logs only i can't find any deny logs.
dominic.caron Sun, 10/21/2007 - 05:44
  • Silver, 250 points or more
You dont have the command on your deny statement.
please rate helpful post
welcomeccie Sun, 10/21/2007 - 06:03
Sorry find below the ACL
logging monitor informational
SW4507#sh access-lists | inc deny
1060 deny ip any any log (1260 matches)
590 deny ip any any log (125 matches)
760 deny ip any any log
590 deny ip any any log (42 matches)
30 deny ip any any log
80 deny ip any any log
1650 deny ip any any log (16491945 matches)
610 deny ip any any log (1691 matches)
Extended IP access list Test
10 deny ip 10.7.92.0 0.0.0.255 10.7.6.0 0.0.0.255
30 deny ip any any log-input
SW#sh loggi
Syslog logging: enabled (0 messages dropped, 7 messages rate-limited, 0 flushes,
0 overruns, xml disabled, filtering disabled)
Console logging: level debugging, 26462 messages logged, xml disabled,
filtering disabled
Monitor logging: level informational, 0 messages logged, xml disabled,
filtering disabled
Buffer logging: level debugging, 177098 messages logged, xml disabled,
filtering disabled
Exception Logging: size (8192 bytes)
Count and timestamp logging messages: disabled
Trap logging: level informational, 177102 message lines logged
Logging to 55.4.8.2, 177102 message lines logged, xml disabled,
filtering disabled
Richard Burts Wed, 10/24/2007 - 11:52
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
This response shows denies from multiple access lists and we have no way to know which deny goes with which access list (which deny is the one related to the original post?). It would be much better if you were to just list show access-list so that we could see the entire list and understand the context.
In looking at the original post it does suggest that there are permit lines which include the log parameter and the deny does not:
It would really help if we could see the access list. And showing it out of the config would probably be better than out of show access-list.
Rick
amit.secure1 Fri, 10/26/2007 - 01:16
You have to configure syslog server for recving all log of PIX..and you can't log locally(means on PIX itself) all logs bcze it's mostly firewall genrated so many logs and due to limited HDD space on PIX, pix wil stop working after full HDD..so enable syslog on pix and rcvd log on other configured server to view ALL LOGS..........pls let me know for any further clearfication..........
