USB to Telnet
Oct 21st, 2007
I'm looking for some softwares that can do the following:
Connect to the equipment with a console port. than forward the connection as a telnet server.
This way a local equipment can ba accessed via console port remotly.
I'm not sure that this kind of software in availible, but I think that's the way Cisco Remote Labs works.
Any suggestion??
Overall Rating: 2.5 (2 ratings)
mfreijser Mon, 10/22/2007 - 01:00
  • Bronze, 100 points or more
Maybe a 'console server' is what you're looking for. I don't have any experience with this kind of servers or software, but i know there's loads of information on Google if you type in 'console server'.
Michael
omar.elmohri Tue, 10/23/2007 - 00:57
That's interessting, but what I'm needing is just a server for a small LAB
mfreijser Tue, 10/23/2007 - 01:05
You could take an old pc and put some PCI cards with serial interfaces in it (like this one: http://www.coolgear.com/images/165273.jpg).
You can control the pc via a Remote Desktop connection, voilá; a simple console server!
Michael
omar.elmohri Tue, 10/23/2007 - 01:11
Haha that's the easiest, but not interesting for me, I like to use this software in client sites where I can access in any case of problem, with a remote desktop if I connect with a ISDN 56kbps connection that will not be the best way to do.
