Problem with T1 bridge w/2 1720 routers performance slow
Oct 21st, 2007
I have a partial bridged T1 using 2 Cisco 1720 routers and the speed is very slow from lan to lan.
Here is the config:
Using 646 out of 29688 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname GW-MAC
logging queue-limit 100
enable secret 5 xxxxxxxxx
enable password xxxxxxx
memory-size iomem 25
ip subnet-zero
no ip routing
interface FastEthernet0
no ip address
no ip route-cache
no ip route-cache
full-duplex
bridge-group 1
interface Serial0
ip address 192.168.20.201 255.255.255.0
encapsulation ppp
no ip route-cache
bridge-group 1
ip classless
no ip http server
bridge 1 protocol ieee
line con 0
line aux 0
line vty 0 4
password xxxxxx
login
no scheduler allocate
Same config both sides with different host name and IP.
Overall Rating: 5 (1 ratings)
pciaccio Sun, 10/21/2007 - 10:07
  • Silver, 250 points or more
Try enabling route cache on all interfaces involved. So for the FE0 and Ser 0 use the IP ROUTE-CACHE. Do this for the remote end as well... This will speed up the processing speed through the routers/bridges... Also verify the T-1 is no taking any errors. Do you have a full T-1 bandwidth or a fractional speed T-1? Verify that your DS0's are set up correctly and the same goes for the remote end... Good Luck..Please rate...
xtremenet Sun, 10/21/2007 - 10:24
I will try the Cache. It is a partial T1 with 20 channels. The following is my new config.
ip subnet-zero
no ip routing
no ip address
no ip route-cache
speed auto
full-duplex
bridge-group 1
interface Serial0
encapsulation ppp
no ip route-cache
service-module t1 timeslots 20
bridge-group 1
ip classless
no ip http server
Richard Burts Sun, 10/21/2007 - 12:09
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Vern
Since you have configured no ip routing on the router there will not be any ip route cache anyway. So configuring no ip route-cache will not change anything.
Perhaps I am a bit confused in your original post you referred to it as a partially bridged situation. With no ip routing configured and bridge-groups on the interfaces it looks fully bridged to me. Was the partial in reference to the partial T1 or is it something else that you meant?
Since you are taking traffic that normally moves at 100 Mb and sending it over a link of about 1.2 Mb (including all the broadcast traffic that is normal on a LAN) I would expect an impact on performance. What does the traffic level look like in show interface serial 0? (It might help to make the measurement interval 30 seconds instead of the normal 5 minutes so that you get a better picture of traffic that may be bursty) I am guessing that the slowness is the impact of the slow link.
Rick
xtremenet Sun, 10/21/2007 - 15:28
Rick,
It's in reference to the T1. It is fully bridged. The circuit was bridged through 2 Adtran 850's with a different ISP. The switched ISP's and we purchased 2 1720'S. Now the circuit uses the same amount of T1 channels but the performance with RDP and Citrix is very poor.
Richard Burts Sun, 10/21/2007 - 16:13
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Vern
Thanks for clarifying what was partial. That makes sense.
I am not sure how the 850s were set up or what they might have done to optimize performance over the T1. The config of the 1720 is quite straightforward and I have not yet seen any issue in the config that would impact performance. I wonder if there might be some issue with the T1 or with the service module that is preventing full utilization of the T1. Perhaps you could post the output of show interface serial 0 and of show service-module?
Rick
xtremenet Sun, 10/21/2007 - 16:21
I did not have access to the 850's. I will send the info from the serial interface later.
I attempted to enable IP routing remotely and have lost access to the router. I will need to go and attach with the console. I was working from home.
Richard Burts Sun, 10/21/2007 - 17:26
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Vern
I am sorry that you lost access to the router. Turning on IP routing on a device that has been configured only for bridging does carry the risk that access will be lost. I have a couple of suggestions for the next time that you try something like that:
- the IOS allows you to reschedule a reload. You can use the command reload in or reload at hh:mm and the router will reload when you indicate. Before you make changes in the config schedule a reload (allow yourself enough time for the changes plus a little margin). Then make the changes. If the change does make you lose access just wait for the scheduled reload. The reload will get rid of the changes that you made (they were not saved to NVRAM) and gets you back to where you started and you have access again. If you make the changes and still have access (the changes were successful) then use the command reload cancel to cancel the scheduled reload.
- make changes on the remote device first. When you make the change on the remote then access will be lost. But when you make the corresponding change on the near device it may restore access. If you change the near device first and lose access then there is no way to get to the remote to make the corresponding change.
Rick
xtremenet Sun, 10/21/2007 - 19:02
Rick,
here is the serial interface output:
GW-NBG#sho int ser 0
Serial0 is up, line protocol is up
Hardware is PQUICC with Fractional T1 CSU/DSU
Internet address is 192.168.20.201/24
MTU 1500 bytes, BW 64 Kbit, DLY 20000 usec,
reliability 255/255, txload 7/255, rxload 3/255
Encapsulation PPP, loopback not set
Keepalive set (10 sec)
LCP Open
Open: BRIDGECP, IPCP, CDPCP
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 2d03h
Input queue: 2/75/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/3/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 48 kilobits/sec
5 minute input rate 1000 bits/sec, 2 packets/sec
5 minute output rate 2000 bits/sec, 4 packets/sec
71290 packets input, 9355206 bytes, 0 no buffer
Received 13344 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
111724 packets output, 6017973 bytes, 0 underruns
1 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
GW-NBG#
Richard Burts Mon, 10/22/2007 - 02:47
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Vern
This certainly does not show much load on the serial interface. I wonder whether it represents a time when users are trying to do something and experiencing slowness or is it Sunday night when there is little traffic (which I suspect is the case)? In which case it might help to do the show commands again at a time when it is more busy.
I do not a couple of things:
- the interface things that its BW is only 64 K where your post indicates that it should be over 1 Mb (BW 64 Kbit) and that after allowing for overhead the remaining bandwidth is 48 K (Available Bandwidth 48 kilobits/sec). We might want to check into why this difference.
- I notice that IPCP is open on the serial interface. This is appropriate since there is an IP address configured on the interface. Since the router is just bridging the IP address could be on any interface. I suggest moving the IP address from the serial interface to the FastEthernet interface (on both routers) and see if that makes any difference.
Rick
xtremenet Mon, 10/22/2007 - 07:19
Rick,
You are correct about Sunday. They are in the office today and it's very slow.
Should I set the bandwidth on the serial interface?
I will need to go to each sight to change the IP to the Fast Ethernet.
xtremenet Mon, 10/22/2007 - 08:39
I believe I may have some issues with the clocking. Could be due to a noisy serial interface. I will replace the cables with sheilded.
I am not sure if I should set the clock rate.
ilya.varlashkin Mon, 10/22/2007 - 02:49
1720 is not up for job - it's too slow. Bridging on this platform is done in the software, and process switching performance of this router is only some 700Kbps.
Besides, bridging fast LAN links over slow WAN link will quickly fill up interface buffers so you'll see a lot of packet drops.
Best solution would be to redesign your setup so that traffic between LAN's is routed and only really necessary traffic is sent over the WAN link.
Paolo Bevilacqua Mon, 10/22/2007 - 07:35
  • Hall of Fame,
    Founding Member
Actually there is no problem in using bridging on a 1720 with T1.
The normal routers including 1720 do everything in software, bridging, routing or whatever.
I agree that a routed design would be easier to design, implement and troubleshoot. But technically speaking, the performances should be the same.
xtremenet Mon, 10/22/2007 - 08:44
The only traffic passing through the bridge is RDP (Remote Desktop) and some internet.
The bridge should handle this without a problem. I do think I have a clocking issue due to a noisy serial connection. I am currently preparing to change cables and troubleshoot the serial interfaces.
ilya.varlashkin Mon, 10/22/2007 - 09:03
what out for Windows name resolutions, which sometimes can go as broadcasts.
As regards to performance of this router - even though everything on this router is implemented in software, yet with CEF performance is higher and can be upto 4Mbps, yet without CEF it's only 700Kbps. Software bridging is of the same performance as software switching - 700Kbps.
Richard Burts Mon, 10/22/2007 - 09:11
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Vern
How are you managing to restrict traffic through the bridge to RDP and some Internet? Normally all broadcast, all multicast, and all unicast for destinations on the other side of the bridge are carried by the bridge (which is one reason that we generally recommend not to bridge LAN over T1).
There certainly might be a clocking issue or a noisy line issue and if so it could explain the poor performance. It might give us some insight into the issue if you would post the output of show service-module
Rick
xtremenet Mon, 10/22/2007 - 09:26
Rick
I am not running WINS. I have some broadcasts but very little. That is why you saw very little traffic on the sho int ser 0 on Sunday.
I have contacted the ISP to check the provisioning of the T1.
I am begining to think I should route instead of bridge. I would like to solve the serial interface issue first. The following is the sho service-module. I did notice the timeslots = 1, odd!
GW-NBG#sho service-module
Module type is T1/fractional
Hardware revision is 0.96, Software revision is 0.2,
Image checksum is 0x73D70058, Protocol revision is 0.1
Receiver has no alarms.
Framing is ESF, Line Code is B8ZS, Current clock source is line,
Fraction has 1 timeslots (64 Kbits/sec each), Net bandwidth is 64 Kbits/sec.
Last module self-test (done at startup): Passed
Last clearing of alarm counters 2d17h
loss of signal : 0,
loss of frame : 0,
AIS alarm : 0,
Remote alarm : 1, last occurred 2d17h
Module access errors : 0,
Total Data (last 96 15 minute intervals):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Data in current interval (108 seconds elapsed):
GW-NBG#
Richard Burts Mon, 10/22/2007 - 09:37
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Vern
The line about Fraction has 1 timeslots (64 Kbits/sec each), Net bandwidth is 64 Kbits/sec is certainly something to check out. If true it would certainly explain the poor performance.
Rick
xtremenet Mon, 10/22/2007 - 09:41
Rick
In my config I have the service-module T1 timeslots = 20 on both routers. If the timeslots were misconfigured I thought I would not bring up the circuit.
Any idea how this is possible?
Richard Burts Mon, 10/22/2007 - 09:59
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Vern
I am not sure how it would happen. I am not sure whether there is any other parameter that might be needed.
I do not have much experience with this issue but I see that there is a debug service-module command. I wonder if you turned on that debug, configured the service module to remove the timeslots and then configured the service-module again with the timeslots, if the debug would tell us anything useful?
Rick
xtremenet Mon, 10/22/2007 - 11:06
Rick,
I have been working with the ISP and they will check the provisioning. I am at the point that I will erase the flash on each router and rebuild. I have another 1720 being shipped in tomorrow (just in case).
I will keep you posted. Than you for all your help!
