Disable IKE Aggressive Mode on VPN 3000 Concentrators
Oct 21st, 2007
Is it possible to disable IKE Aggressive Mode on Cisco VPN Concentrators (running 4.1.7)? I have checked the SA configuration under Traffic Management, and the 'Negotiation Mode' IKE Parameters is set to 'Main' for the SA (and all SAs), but the debugs suggest Aggressive mode is being used during IKE Phase 1 negotiation. I suspect the VPN Client is requesting Aggressive mode, and the Concentrator is honouring it.
