EasyVPN server-client, serverside-initated traffic wont work
Oct 21st, 2007
Hej
I've configured an ASA5510 as a central Easu VPN-server. A home office user hasa a ASA5505 that is configured as a VPN Client (the vpnclient-commands). The tunnel works great, but there is an application that initiates TCP-sessions from the Hub-lan destinated to the computer at home, behind the ASA5505 VPN-client. And this traffic won't work. And Now I am uncertain. Should this work or not?
Topology: Central net: 172.17.1.0/24 and a few other 172.17.x.y-nets
Home-net: 172.18.8.0/28 (central ASA config prepared for more future home networks in the 172.18.8.0/24-range
Relevant server-side configuration:
access-list Inside_nat0_outbound extended permit ip object-group Internal-network 172.17.8.0 255.255.255.0
access-list VPN5005_split_tunnel extended permit ip object-group Internal-network 172.17.8.0 255.255.255.0
nat (inside) 0 access-list Inside_nat0_outbound
crypto ipsec transform-set tset_VPN5005 esp-aes esp-sha-hmac
crypto dynamic-map dmap_VPN5005 5 set transform-set tset_VPN5005
crypto map Outside_map 100 ipsec-isakmp dynamic dmap_VPN5005
crypto isakmp policy 20
authentication pre-share
encryption aes
hash sha
group 5
lifetime 86400
group-policy gp_VPN5005 internal
group-policy gp_VPN5005 attributes
split-tunnel-policy tunnelspecified
split-tunnel-network-list value VPN5005_split_tunnel
nem enable
username VPN5005_user1 password password
tunnel-group tg_VPN5005 type ipsec-ra
tunnel-group tg_VPN5005 general-attributes
default-group-policy gp_VPN5005
tunnel-group tg_VPN5005 ipsec-attributes
pre-shared-key djhkj334kjhdkj3222
home-side configuration:
interface Vlan1
nameif inside
security-level 100
ip address 172.17.8.1 255.255.255.240
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
vpnclient server x.x.x.x
vpnclient mode network-extension-mode
vpnclient vpngroup tg_VPN5005 password djhkj334kjhdkj3222
vpnclient username VPN5005_user1 password password
vpnclient enable
So, an user behind the 5505 has IP 172.17.8.10. The computer has full connectivity to all central servers on the 172.17.1.0-net. However, a server needs to initiate a TCP-session to 172.17.8.10 and it won't work. Should it work? Or do we need a solution with a Lan-2-Lan-tunnel with static IP at home to get this thing working?
Thanks for all feedback!
/Jimmy
