Not so easy VPN...
Oct 21st, 2007
I've got a pair of 2611XM's that are running as internet routers for at two branch offices. They're both performing pppoe negotiation over a fast eth/dial interface. The dialer interface is ip nat outisde. The other fast eth interface is running with private LAN addresses and ip nat inside.
One of these branch offices has remote workers that connect using the VPN client which gives them a local LAN ip address etc. This worked great, first time around for a change. However my intent was to configure the remote branch router to VPN into the Easy VPN Server as well. I haven't been able to get it to work was wondering if anyone could help!
Outputs from debug show that Phase 2 is failing.
<10.1.1.0/24>-2611XM-<Internet>-2611XM-<192.168.2.0/24>
Server side config
username user priv 15 pass <password>
crypto isakmp client configuration group REMOTE_LOGIN
key 6 <key>
dns 10.1.1.1
pool VPN_POOL
acl SPLIT_TUNNEL
save-password
include-local-lan
pfs
max-users 20
max-logins 2
netmask 255.255.255.0
banner ^CConnection Secured^C
crypto isakmp profile ISAKMP_PROFILE
match identity group REMOTE_LOGIN
client authentication list LOCAL_AUTH
isakmp authorization list NETWORK_AUTH
client configuration address respond
virtual-template 1
crypto ipsec transform-set VPN esp-aes esp-sha-hmac
crypto ipsec profile IPSEC_PROFILE
set security-association idle-time 3600
set transform-set VPN
set isakmp-profile ISAKMP_PROFILE
interface FastEthernet0/0
description LAN Interface
ip address 10.1.1.1 255.255.255.0
ip nat inside
ip virtual-reassembly
interface FastEthernet0/1
description Connection to ADSL Modem
no ip address
pppoe enable group global
pppoe-client dial-pool-number 1
interface Virtual-Template1 type tunnel
ip unnumbered FastEthernet0/0
ip nat inside
tunnel mode ipsec ipv4
tunnel protection ipsec profile IPSEC_PROFILE
interface Dialer1
bandwidth 14000
ip address negotiated
ip nat outside
encapsulation ppp
ip route-cache flow
ip tcp adjust-mss 1400
dialer pool 1
dialer idle-timeout 0
no cdp enable
ppp authentication chap callin
ppp pap sent-username <username> password 7 <password>
ip local pool VPN_POOL 10.1.1.100 10.1.1.120
access-list SPLIT_TUNNEL permit ip 10.1.1.0 0.0.0.255 any
Remote side config
crypto ipsec client ezvpn remote
connect manual
group REMOTE_LOGIN key 6 <key>
mode client
peer <hostname>
username user password 6 <password>
xauth userid mode local
Any help would be greatly appreciated!
