2800 or 3800 router Forwarding rates?
Answered Question
Oct 21st, 2007
Due to some IP/layer three changes on a provider, we need to introduce a WAN router into our network. The link is a metro ethernet internet pipe @ 10Mbps, and yes, we pretty much have the pipe saturated at 100%/10Mbps most of the time. I am not finding anything noting the forwarding rates for either devices. Any suggestions on which router would be better? Am I nuts for looking at these and should really be looking at a 7200?
The router also would not be doing anything but layer 3 routing of public IP addresses in a static config with some possible QoS. The physical requirements are two routed FE or GE interfaces, 1 to LAN, 1 to provider. Also, I would like to plan for some headroom for much needed additional bandwidth.
Correct Answer by andrew.burns about 9 years 6 months ago
Go to this page:
http://www.cisco.com/web/partners/tools/quickreference/index.html
Scroll down and check out the "Router Performance" pdf, it should give you all the info you need.
Andrew.
Overall Rating: 5 (1 ratings)
jrrandall Mon, 10/22/2007 - 09:38
Thanks Andrew. That is exactly what I what I needed.
ilya.varlashkin Mon, 10/22/2007 - 02:25
  • Silver, 250 points or more
For your setup take c1812 router. I've done a lot of performance testing with this router in the lab and find it best router for the money whether without or with IPsec and/or QoS.
