CME Calling Number Display Malformed
Answered Question
Oct 21st, 2007
We have CME 4.2 running on a 2811 router, and when incoming local calls come in - the display on the ip phone is a strange variety of characters. I have included a screenshot (ip comm as I dont have a digital camera handy) and also the debug q.931. Does any have any ideas why this would display as so?
Unknown numbers show up as 'unknown' however.
THanks,
Correct Answer by paolo bevilacqua about 9 years 7 months ago
Which exact IOS is this ? Do you need any specific 4.2 feature or can you use 12.4(11)XJ4 sthat is stable and has many bugs fixed ?
Overall Rating: 4.5 (2 ratings)
Correct Answer
paolo bevilacqua Mon, 10/22/2007 - 01:00
  • Hall of Fame,
    Founding Member
mattiep00 Mon, 10/22/2007 - 01:16
I'm using Version 12.4(11)XW3.
This was happening to me on version 3.3 on a 2651 as well, so i dont think it's a CME issue.
I will download and test now. Any other ideas?
paolo bevilacqua Mon, 10/22/2007 - 01:53
  • Hall of Fame,
    Founding Member
XW4 has also been released. I see funny characters on my IP communicator too at times, which version are you using ?
mattiep00 Mon, 10/22/2007 - 02:06
Version 2.0.2 of the Communicator. Its also on the phones (using load P0030800500).
Ive just replaced the image, and gone back to P0030800400 so will be able to test in a little while.
What is you incoming dial-peer, and Serial port set to?
Mine are:
dial-peer voice 1 pots
description ** PRI POTS Incoming dial-peer **
incoming called-number ....
direct-inward-dial
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
isdn bchan-number-order ascending
no cdp enable
paolo bevilacqua Mon, 10/22/2007 - 02:48
  • Hall of Fame,
    Founding Member
for this problem, the config really doesn't matter. There is FW 8.0(7) available for the phones, that you can try.
mattiep00 Mon, 10/22/2007 - 02:50
Well, strange things. after re-loading IOS to CME4.1 when I dial myself it comes up properly! The site is in Singapore, so need to wait until tomorrow to get someone to test properly but it looks like there may be an issue with CME4.2!
Will post results tomorrow night!
Thanks for your help though
I'm running into the exact same incoming call strange character issue.
CME 4.2 running on a 2811 router. The exact IOS image that I'm using:
c2800nm-advipservicesk9-mz.124-11.XW1.bin
I'm holding off on downgrading back to 4.1 so I tried downgrading the phone firmware. The firmware was SCCP 8-2-2SR2 and I tried the older SCCP 8-2-2SR1. That did not help.
Anyone find a resolution to this issue while remaining on 4.2?
- Nate
paolo bevilacqua Sun, 03/09/2008 - 17:45
  • Hall of Fame,
    Founding Member
Hi, can you try XW6?
There's a bazillion of bugs fixed from XW1.
paolo bevilacqua Sun, 03/09/2008 - 18:23
  • Hall of Fame,
    Founding Member
That was fast! The gui files IMHO are so poorly written that know little difference between CME XWhatever and a kitchen sink.
Thanks for the nice rating and good luck!
