Problem with Cisco 1721 + ACS 4.0 and VPND windows users auth
Oct 22nd, 2007
I used this example for making VPND server with radius auth for WinXP SP2 users -
But users cant pass auth - in ACS logs i see what everything is ok - status in passed auths is - Authen OK.
Debug output and config file are in attach.
Thanks in advanced.
Overall Rating: 5 (1 ratings)
Premdeep Banga Mon, 10/22/2007 - 03:52
debug indicate that radius is responding, and in debugs we can see,
"RADIUS: response-authenticator decrypt fail, pak len 126"
Device is somehow not able to decrypt the response. Generally its due to shared secret mismatch. But I don't think that's the case.
Please check if this applies,
CSCsh02500 : L2TPv2 calls fail when receiving hidden AVPs
hyperglobus Mon, 10/22/2007 - 21:44
1st - i checked key between cisco and ACS (because found a lot of examples of this error), after this i checked also users and passwords - because this group in ACS is maped to Windows AD.
L2TPv2 calls fail when receiving hidden AVPs ???
