How to make call reject?
z.zdravkov
I have CallManager 4.2 and I want to make call reject functionality when the phone is on-hook and ringing. There is only answear and iDivert softkeys in this mode. It is possible to make iDivert to invalid number but I'm looking for more elegant solution.
paolo bevilacqua
Are you using H.323 to the GW ?
If so it could be possible to idevert to a service that disconnects the call and does not actually answer or give busy tone. Howeve depending on the network, that may have the same effect to the caller.
Yes, I consider this solution but I'm looking for something better because iDevert is not that intuitive.
