how to find which platform support the specific feature.
Answered Question
how to find which platform support some specific feature.
for example,which switch platform support DAI.
Correct Answer by ankbhasi about 9 years 7 months ago
Hi Jian,
You can use Feature Navigator and then click on search by feature and type full feature name of select from the availbale list and then you will get products and releases which support that feature.
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Ankur
*Pls rate all helpfull post
Overall Rating: 5 (1 ratings)
Correct Answer
ankbhasi Mon, 10/22/2007 - 02:04
  • Cisco Employee,
Hi Jian,
Ankur
