TCP reassembly queue overflow on Cisco 877 VPN router
Oct 22nd, 2007
I keep getting this error on my syslog server from one of my Cisco 877 VPN ADSL routers:
60: Dropping TCP Segment: seq:3959461132 1420 bytes is out-of-order; expected seq:3959437672. Reason: TCP reassembly queue overflow - session to
What does it mean?
owillins Fri, 10/26/2007 - 06:17
Can you please verify the "show ip inspect statistics" and the version of IOS in use? You will likely need to up the out-of-order max queue length.
Would it be possible to increase the queue size for out of order packets
#ip inspect tcp reassembly queue Length 64
ip inspect tcp reassembly {[queue length packet-number] [timeout seconds] [memory limit size-in-kb] [alarm {on | off}]}
whiteford Fri, 10/26/2007 - 07:36
It's IOS version c870-advipservicesk9-mz.124-15.T1.bin
Packet inspection statistics [process switch:fast switch]
tcp packets: [1712052:14818230]
udp packets: [191:42150]
packets: [182:30946]
http packets: [41279:273990]
Interfaces configured for inspection 1
Session creations since subsystem startup or last reset 70271
Current session counts (estab/half-open/terminating) [2:0:0]
Maxever session counts (estab/half-open/terminating) [95:14:9]
Last session created 00:01:01
Last statistic reset never
Last session creation rate 0
Maxever session creation rate 255
Last half-open session total 0
TCP reassembly statistics
received 10063 packets out-of-order; dropped 708
peak memory usage 37 KB; current usage: 0 KB
peak queue length 16
let me know if i need to change anything
