dynamic ACL's needed
I have two aplications that need to be accessed fist to sqlnet port 1521 and then it gives the client a port over 1024.
The thing is that it doesn't work if I try to do this access dinamically because I have a rule that accept >1024 and not only the 1521 port.
It's like the FTP dynamic port, it doesn't work.
How I do it to work in a ASA 5520?
Thanks. Regards
Overall Rating: 3.5 (2 ratings)
irisrios Fri, 10/26/2007 - 06:21
Make sure the source and destination ports are correctly applied to the interface in the specific direction.
Rafiki-TLK Sun, 10/28/2007 - 03:52
All you need to do is open port 1521 and inspect sqlnet.
Please see details for the inspect sqlnet command.
This will make ASA/PIX track the changes in the connection starting at port 1521 and changing to what ever port Oracle DB chooses.
Regards Rafiki-TLK
