Error while Saving configuration on ASA
Oct 22nd, 2007
I do get the following error while saving the configuration to memory on my ASA box.
HCL-BMB-ASA-PRI# wr mem
Building configuration...
Cryptochecksum: 42bceaba 27adb265 edcb9fbd 60a1761e
%Error opening disk0:/.private/startup-config (File or directory already in use)
Error executing command
[FAILED]
show version is as follows:
HCL-BMB-ASA-PRI# sh vers
Cisco Adaptive Security Appliance Software Version 7.0(6)
Device Manager Version 5.0(6)
Compiled on Tue 22-Aug-06 13:22 by builders
System image file is "disk0:/asa706-k8.bin"
Config file at boot was "startup-config"
HCL-BMB-ASA-PRI up 38 days 21 hours
failover cluster up 38 days 22 hours
Hardware: ASA5510, 256 MB RAM, CPU Pentium 4 Celeron 1600 MHz
Internal ATA Compact Flash, 256MB
BIOS Flash M50FW080 @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-55x0 on-board accelerator (revision 0x0)
Boot microcode : ☻CNlite-MC-Boot-Cisco-1.2
SSL/IKE microcode: ♥CNlite-MC-IPSEC-Admin-3.03
IPSec microcode : ☺CNlite-MC-IPSECm-MAIN-2.04
0: Ext: Ethernet0/0 : address is 001b.2a34.e6f6, irq 9
1: Ext: Ethernet0/1 : address is 001b.2a34.e6f7, irq 9
2: Ext: Ethernet0/2 : address is 001b.2a34.e6f8, irq 9
3: Ext: Ethernet0/3 : address is 001b.2a34.e6f9, irq 9
4: Ext: Management0/0 : address is 001b.2a34.e6fa, irq 11
5: Int: Not licensed : irq 11
6: Int: Not licensed : irq 5
Licensed features for this platform:
Maximum Physical Interfaces : Unlimited
Maximum VLANs : 25
Inside Hosts : Unlimited
Failover : Active/Standby
VPN-DES : Enabled
VPN-3DES-AES : Enabled
Security Contexts : 0
GTP/GPRS : Disabled
VPN Peers : 150
This platform has an ASA 5510 Security Plus license.
Serial Number: JMX1129L0VH
Running Activation Key: 0x46186153 0x1837dcd1 0x00d25d44 0xa8e47044 0x4b142883
Configuration register is 0x1
Configuration last modified by enable_15 at 12:53:21.573 IST Tue Oct 9 2007
Please help me asap!!!
Subhash.
1cmerchant Mon, 10/22/2007 - 04:13
You probably need to call TAC to get this resolved, but in the meantime you could write the configuration to a tftp server. That way at least you'll have a copy of the configuration in case the device goes down.
Use the 'tftp-server' command to specify the interface and IP address of the tftp server, and then a 'write net' command to actually write the config to it.
palukuri77 Mon, 10/22/2007 - 22:53
Thanks for your response. I've the config and also failover ASA working. Opened a TAC case but just thought someone would have faced a similar issue and could throw some light on this.
Subhash.
