Sh ip int brief - VLAN Method.
rwamstutz
All, When I do a 'sh ip int brief', the method for my VLANs are different. Some are NVRAM, others are manual? How come and do they all need to be NVRAM? How do I change that?
Much Appreciated.
Richard Burts
Rob
If you check I believe that you will find that the VLANs that indicate NVRAM were configured before the last time that the router/switch reloaded and that the VLANs that indicate manual were configured since the last reload. If you want all of them to indicate NVRAM then you should save your config and reload. Then they will all be consistent. From my perspective I am not sure that it is worth the reload. But if you want them consistent a reload is the way to do it.
Rick
Rick
