communication in between clusters
Oct 22nd, 2007
How to make the communication in between two clusters (each is having 3000 ip phones)of same capacity,if any trunk is needed
sadbulali Fri, 10/26/2007 - 08:06
You should have gateways to communicate between the clusters
Tommer Catlin Fri, 10/26/2007 - 08:41
Why would you need gateways between the clusters? I thought ICT just uses IP. If the clusters can communicate through the WAN through IP, you should be able setup ICT on each cluster, point to each other. Create Route patterns to the ICT Trunks and voila!, you can call be between clusters.
