ccme help
Oct 22nd, 2007
what do i need to do forward all traffic from my router (2811) that has to do with voice to an asa5505?
Overall Rating: 5 (1 ratings)
Paolo Bevilacqua Mon, 10/22/2007 - 06:54
If you have a free public IP, configure a static NAT for it on the asa. That is the simplest and safest method.
konstaninosoregano Mon, 10/22/2007 - 23:17
i dont have a free public ip,
on my router, i have a static nat translation that forwards everything that comes to my public ip inwards to my asa
Paolo Bevilacqua Tue, 10/23/2007 - 03:41
If you can have the cme and the router talk directly without going thru the asa, it would be simpler. CME being a router does not need firewall and would see only SIP to the eternal world.
In that case you setup a static inside nat tranalstion for port 5060 to the cme:
ip nat inside source static udp 5060 interface 5060
Hope this helps, please rate post if it does
konstaninosoregano Mon, 10/29/2007 - 07:06
sorry for the late reply, i have been swamped.
the cme is on the router.i bought the package
i will add the static nat translation, but to the firewall though.
Any additional info would be very much appreciated.
