CDR and CallManager 5.1(2)
Oct 22nd, 2007
Hello, i can't find out how to make CDR works on my cluster of CUCM 5.1(2) (one pub/one subs). I always have "unsuccessful" log when checking "CDR Load" event log.
I have no connectivity issue nor services misconfiguration. I only see this log in RTMT:
2007-10-22 13:20:20,272 ERROR [DailyCdrLoad] controller.CtrLoader - run(): Manual Purge Process is running. So intentionally failing the loader. Loader continues once manual purge is complete
2007-10-22 13:20:20,274 ERROR [DailyCdrLoad] controller.CtrLoader - run(): Error runnning loader.
Like the publisher stuck in whatever process...
Thanks a lot for your help.
Julien.
Overall Rating: 3 (2 ratings)
jtoque Wed, 11/28/2007 - 06:49
I found the solution. I run this command to unlock the manual purge process:
run sql update car:tbl_system_preferences set param_value='0' where param_name='MANUAL_PURGE_STATUS'
Julien.
