6506-e - RME Error
Oct 22nd, 2007
While trying to pull config for a 6506e get this error:CM0056 Config fetch failed for g0ghq3esw1 Cause: CM0204 Could not create DeviceContext for 17118 Cause: CM0206 Could not get the config transport implementation for 10.160.8.29 Cause: UNKNOWN Action: Check if required device packages are available in RME. Action: Check if protocol is supported by device and required device package is installed.
What updates do I need?
Joe Clarke Tue, 10/23/2007 - 08:03
What is the sysObjectID from this device? You can find that under Device Center > SNMP Walk. Just walk sysObjectID.
rice.randy Thu, 10/25/2007 - 10:36
I just noticed that no configs for my 6504-e's are pulling. What updates do I need to to for CW to pull.
CM 4.0
DFM 2.0
IPM 2.6
RME 4.0
If updates are required, what order are they to be installed?
Joe Clarke Thu, 10/25/2007 - 11:04
These are not complete versions. What is the exact version of RME you have, plus, what is the sysObjectID of this switch?
rice.randy Fri, 10/26/2007 - 04:18
RME - 4.0.5
SysObjectID - RFC1213-MIB::sysObjectID.0 = OID: CISCO-SMI::ciscoProducts.657
Joe Clarke Sun, 10/28/2007 - 13:53
Support for this switch is available in Cat6000IOS package version 6.1. This package can be downloaded via the Common Services > Software Center > Device Update interface.
rice.randy Mon, 10/29/2007 - 06:38
While installing CAT6000ios GOT this error:
Cat6000IOS
WARNING : Cat6000IOS(6.1):Consistency check failed for base package SharedInventoryCatIOS
ERROR: Error while installing (SharedNetshowSC): D:appsCSCOpx emppsuinstall
meSharedNetshowSC.zip cannot be installed because, the current mdf version:1.12 is LESS THAN the minimum required mdf version:1.16
Where do I fin MDF 1.16?
Joe Clarke Mon, 10/29/2007 - 06:59
The MDF is found by selecting Common Services in addition to RME when performing the Device Update. Select all available updates.
rice.randy Mon, 10/29/2007 - 07:44
For Product(s) : Resource Manager Essentials
Install Invoked by user : admin
The Package(s) Selected for Install :
I installed MDF update and still get this message while trying to install CAT6000IOS package:
LibCommon
ERROR: Error while installing (LibCommon): C:psu_download
meLibCommon.zip cannot be installed because, the current mdf version:1.12 is LESS THAN the minimum required mdf version:1.19
Joe Clarke Mon, 10/29/2007 - 07:49
You must not have installed the MDF correctly. The current latest version is 1.21. This time, select just Common Services, pick the MDF 1.21 update, and install it. That should prompt a daemon restart. When you're able to login again, then install the RME updates.
rice.randy Mon, 10/29/2007 - 07:57
When I select Common Services and go get the download I get :
All the available package(s) at source location are already installed.
Dosen't this mean that the current MDF is already installed?>
Joe Clarke Mon, 10/29/2007 - 07:59
If you click on the CiscoWorks Common Services link under Device Update, what do you see?
rice.randy Mon, 10/29/2007 - 08:08
I select Common Services,
I click "Check for Updates"
I get the source location display,
I select Cisco.com,
I enter my CCO info,
I click next, then I get :
Joe Clarke Mon, 10/29/2007 - 08:10
No, just click the hyperlink "CiscoWorks Common Services" under Common Services > Software Center > Device Update.
rice.randy Mon, 10/29/2007 - 08:13
Package Map
Filter Source: Package Name Version
Showing 1-1 of 1 records
Package Name Version Description
1. Mdf 1.12 MDF Package
