Dennis Fogler Mon, 10/22/2007 - 06:44
Adding CTI ports is similar to adding IP Phones. You can just add them in Call Manager and associate them to the JTAPI user. This should not cause a server restart. You will also need to add them to a CTI port group within CRS.
joepapesh Mon, 10/22/2007 - 07:13
You didn't mention the version of UCCX, however, I believe all versions starting with 4.x require that you build the CTI ports within UCCX. The UCCX server will then build them in Call Manager. I would definitely do it after hours.
I can tell you that I had a problem with "out-of-sync" ports because they had been built by out integrator on Call Manager independent of UCCX (we use 4.0(5)).
I hope this helps...
--Joe
